Data disappears when you add LUNs to a volume group
Data on the LUN disappears, when you add an existing LUN to a volume group.
If you add an existing LUN to a volume group that is managed by the LVM, and then execute a pvcreate command, the data is overwritten.
Workaround
If you need data that is on an existing LUN, you must migrate that data to a LUN that you create using the LVM. Complete the following steps.
Create new LUNs.
Place the LUNs under LVM control by using the
pvcreate, thevgcreate, and thelvcreatecommands. -
Copy data from the existing LUNs to the LUNs you created and placed under LVM control.
