Guidelines for the storage create operation
You should follow certain guidelines when you use the snapdrive storage create command for the storage create operation.
If you list LUNs from different storage system volumes with the -lun option, you cannot include the
-dg,-hostvol, or-fsoption at the command prompt. -
The
-nolvmoption creates a file system directly on a LUN without activating the host LVM.You cannot specify host volumes or disk groups when you use this option.
You cannot use SnapDrive for UNIX storage provisioning commands for NFS files or directory trees.
If you use the
snapdrive storage createcommand to create a file system directly on a LUN, you cannot specify more than one LUN.SnapDrive for UNIX always creates a new LUN when you use this form of the command.
Some operating systems have limits on how many LUNs you can create.
If your host is running one of these operating systems, you might want to run the
snapdrive config check lunscommand. -
Creating a file system on a raw LUN with DMP multipathing is supported.
The
enable-mount-with-netdevparameter allows you to include the_netdevfile system option with the/etc/fstabfile.When the value is set to off (default value), you must manually specify
-mntopts _netdevin thesnapdrive storage createcommand. However, if you change the value to on, the-mntopts _netdevis executed automatically when you run thesnapdrive storage createcommand.
Related information
