Guidelines for renaming Snapshot copies
Download PDF of this page
While renaming Snapshot copies, ensure that the two Snapshot copies do not have the same name.
Follow these guidelines when you use the snapdrive snap rename
command:
An error message occurs if you try to rename a Snapshot copy to a different storage system volume.
An error message occurs if the new name for the Snapshot copy already exists. You can use the
-force
option to force SnapDrive for UNIX to change the name without generating an error message.
