LUN discovery fails due to iSCSI daemon limitation
SnapDrive for UNIX commands fail to discover the LUNs after continuous multiple iterations.
You may see the following error message.
0000-001 Admin error: iscsi transport protocol has dropped sessions in the host. Please ensure the connection and the service in the storage system.
This happens because of the iSCSI daemon limitation in the following hosts:
Red Hat Enterprise Linux 4.0
Oracle Enterprise Linux 4.0
Workaround
Before modifying the following system parameters, contact the OS vendor.
Add the
fs.file-maxparameter to the/etc/sysctl.conffile.The following is an example in the command-line.
# sysctl -w fs.file-max=65536
We recommend to set the parameter value to 65536, but you can also set the value depending on the applications on your host. -
Assign
65536to thefs.file-maxparameter. -
Update the default shell
start-upfile for the root user's UNIX account.-
For the Bourne, Bash, or Korn shell, add the following lines to the
/etc/profilefile by running the following command:cat >> /etc/profile <<EOF if [ \$USER = "root" ]; then if [ \$SHELL = "/bin/ksh" ]; then ulimit -p 16384 ulimit -n 65536 else ulimit -u 16384 -n 65536 fi umask 022 fi EOF
For the C shell (csh or tcsh), add the following lines to the
/etc/csh.loginfile by running the following command:cat >> /etc/csh.login <<EOF if ( \$USER == "root" ) then limit maxproc 16384 limit descriptors 65536 endif EOF
Add the following parameters to the
/etc/security/limits.conffile by running the following command:root soft nofile 65536 root hard nofile 65536
Activate all the kernel parameters for the system by executing the following command:
sysctl -p
