Managing storage using a wizard
You can use the SnapDrive for UNIX wizard to create storage in an interactive and efficient manner. The wizard leads you through a set of questions to help you to create storage.
You can launch the wizard by using the snapdrive storage wizard create command.
The following storage management operations can be performed:
Creating a LUN
Creating a disk group and automatically setting up the LUN
Creating a disk group and specifying the LUN.
Creating a host volume and automatically setting up the LUN
Creating a host volume and specifying the LUN
Creating a file system on a LUN and automatically setting up the LUN
Creating a file system on a LUN and specifying the LUN.
Creating a file system on a LUN and setting up the LUN automatically with Logical Volume Manager (LVM) and disk group specified
Creating a file system on a LUN and specifying the LUN with LVM and disk group specified
Creating a file system on a LUN and setting up the LUN automatically with LVM and host volume specified
Creating a file system on a LUN and specifying the LUN with LVM and host volume specified
