Restoring multiple storage entities
PDF of this doc site
Administration for Linux
- Role-based access control in SnapDrive for UNIX
Installation and Administration for Solaris
- Creating and using Snapshot copies in SnapDrive for UNIX
Installation and Administration for IBM AIX
Creating your file...
Your file is ready
You can restore a Snapshot copy that contains multiple storage entities.
To restore a Snapshot copy that contains storage entities that reside on multiple destination storage systems, you must meet the following requirements:
The storage entities you specify at the command prompt must reside on a single storage system, or on a HA pair.
The name of the volume of the source storage system must match the name of the volume of the destination storage system.
You must set the
snapmirror-dest-multiple-filervolumes-enabled
argument in thesnapdrive.conf
file to on.
You can use one command to restore storage entities that reside on a single storage system or on a HA pair.
