Snap connect procedure
The snap connect procedure is valid for Data ONTAP 7.2 or later and explain the steps for snap connect operation.
The following steps depict the snap connect procedure:
SnapDrive for UNIX obtains the file spec name and the Snapshot name from the snap connect CLI. It then finds out the original storage system volume(s) where the snapshot(s) resides.
SnapDrive for UNIX chooses an appropriate cloning method for storage system entities based on CLI configuration options.
If the CLI option is specified, it always overrides the snapdrive.conffile option.-
If
-clone luncloneoption is specified in the CLI or thesan-clone-method=luncloneoption in thesnapdrive.conffile, then SnapDrive for UNIX creates a LUN clone in the same volume from the given snapshot. -
If
-clone unrestrictedoption is specified in the CLI or thesan-clone-method=unrestrictedoption in thesnapdrive.conffile, then SnapDrive for UNIX creates or reuses all-purpose FlexClone from the given Snapshot. -
If
-clone optimaloption is specified in the CLI or thesan-clone-method=optimaloption in thesnapdrive.conffile, then SnapDrive for UNIX automatically chooses between restricted FlexClone and LUN clone, based on storage system configuration.
By default, clones created by SnapDrive for UNIX are backup clones. |
