SnapDrive commands and capabilities
In role-based access control (RBAC), a specific capability is required for each operation to be successful. A user must have the correct set of capabilities assigned to carry out storage operations.
The following table lists the commands and the corresponding capabilities required:
Command Capability
storage show
SD.Storage.Read on volume
storage list
storage create
  • For LUNs inside volumes: SD.Storage.Write on Volume
  • For LUNs inside qtrees: SD.Storage.Write on qtree
storage resize
SD.Storage.Write on LUN
storage delete
SD.Storage.Delete on LUN
snap show
SD.SnapShot.Read on volume
snap list
snap delete
SD.Storage.Delete on volume
snap rename
SD.Storage.Write on volume
snap connect
  • For LUN clones in volume: SD.SnapShot.Clone on volume
  • For LUN clones in qtree: SD.SnapShot.Clone on qtree
  • For traditional volume clones: SD.SnapShot.Clone on storage system
  • For FlexClone volume: SD.SnapShot.Clone on the parent volume
  • For unrestricted Flexclone volumes: SD.SnapShot.UnrestrictedClone on the parent volume
snap connect-split
  • For LUN clones (LUN cloned and split in volume): SD.SnapShot.Clone on volume and SD.Storage.Write on volume
  • For LUN clones (LUN cloned and split in qtree): SD.SnapShot.Clone on qtree and SD.Storage.Write on qtree
  • For traditional volume clones which are split: SD.SnapShot.Clone on storage system and SD.Storage.Write on storage system
  • For Flex volume clones which are split: SD.SnapShot.Clone on the parent volume.
clone split start
  • For LUN clones where the LUN resides in volume or qtree: SD.SnapShot.Clone containing volume or qtree
  • For volume clones: SD.SnapShot.Clone on the parent volume
snap disconnect
  • For deletion of unrestricted volume clones: SD.SnapShot.DestroyUnrestrictedClone on the volume
snap disconnect-split
  • For LUN clones where the LUN resides in volume or qtree: SD.SnapShot.Clone on the containing volume or qtree
  • For volume clones: SD.Storage.Delete on the parent volume
snap restore
  • For LUNs that exist in a volume: SD.SnapShot.Restore on volume and SD.Storage.Write on LUN
  • For LUNs which exists in a qtree: SD.SnapShot.Restore on qtree and SD.Storage.Write on LUN
  • For LUNs which are not in the volumes: SD.SnapShot.Restore on volume and SD.Storage.Write on volume
  • For LUNs which are not in qtree: SD.SnapShot.Restore on qtree and SD.Storage.Write on qtree
  • For volumes: SD.SnapShot.Restore on storage system for traditional volumes, or SD.SnapShot.Restore on aggregate for flexible volumes
  • For single-file snap restore in volumes: SD.SnapShot.Restore on the volume
  • For single-file snap restore in qtree: SD.SnapShot.Restore qtree
  • For overriding baseline Snapshot copies: SD.SnapShot.DisruptBaseline on the volume
host connect, host disconnect
SD.Config.Write on the LUN
config access
SD.Config.Read on the storage system
config prepare
SD.Config.Write on at least one storage system
config check
SD.Config.Read on at least one storage system
config show
config set
SD.Config.Write on storage system
config set -dfm, config set -mgmtpath,
config delete
SD.Config.Delete on storage system
config delete dfm_appliance, config delete -mgmtpath
SD.Config.Delete on at least one storage system
config list
config migrate set
config migrate delete
config migrate list
Note SnapDrive for UNIX does not check any capability for administrator (root).
