Snapdrive for Unix
SnapDrive command fails when the transport protocol connectivity fails
Contributors netapp-ivanad
SnapDrive command fails when the iSCSI or FC connection between the host and storage system fails, or if iSCSI or FC on the storage system fails.
Workaround
To successfully use SnapDrive for UNIX commands, you must first restore the iSCSI or FC service.
