Snapdrive for Unix
Volume-based SnapRestore for space reservation
Contributors netapp-ivanad
For space reservation with volume based snap reserve you need to set space-reservations-volume-enabled option in the snapdrive.conf file.
The space-reservations-volume-enabled option is used to set space guarantee policy on volume and can take the following three values.
  • Snapshot: This is the default value. Space guarantee on the volume does not change.
  • volume: Space guarantee on the volume is at the volume level.
  • none: Space guarantee is set as none.
Following table describes the behavior of volume-based snap reserve for space reservation.
No space reserve CLI option used; -vbsr execute is specified space-reservations-volume-enabled= Result
none
snapshot
none
none
Attempt to set space guarantee as “none” for the volumes.
-reserve
configuration value is over-ridden
Attempt to set space guarantee for volumes as "volume"
-noreserve
Attempt to set space guarantee for volumes as "none"
none
volume
Note -vbsr preview does not check for any of the space reservation options.
