What access control settings are
To determine user access, SnapDrive for UNIX checks one of two permissions files in the root volume of the storage system. You must check the rules set in those file to evaluate access control.
sdhost-name.prbacfile is in the directory/vol/vol0/sdprbac(SnapDrive permissions roles-based access control).The file name is
sdhost-name.prbac, wherehost-nameis the name of the host to which the permissions apply. You can have a permissions file for each host attached to the storage system. You can use thesnapdrive config accesscommand to display information about the permissions available for a host on a specific storage system.If the
sdhost-name.prbacdoes not exist, then use thesdgeneric.prbacfile to check the access permissions. -
sdgeneric.prbacfile is also in the directory/vol/vol0/sdprbac.The file name
sdgeneric.prbacis used as the default access settings for multiple hosts that do not have access tosdhost-name.prbacfile on the storage system.
If you have both sdhost-name.prbac and sdgeneric.prbac files available in the /vol/vol0/sdprbac path, then use the sdhost-name.prbac to check the access permissions, as this overwrites the values provided for sdgeneric.prbac file.
If you do not have bothsdhost-name.prbac and sdgeneric.prbac files, then check the configuration variable all-access-if-rbac-unspecified that is defined in the snapdrive.conf file.
Setting up access control from a given host to a given vFiler unit is a manual operation. The access from a given host is controlled by a file residing in the root volume of the affected vFiler unit. The file contains /vol/<vfiler root volume>/sdprbac/sdhost-name.prbac, where the host-name is the name of the affected host, as returned by gethostname(3). You should ensure that this file is readable, but not writable, from the host that can access it.
To determine the name of the host, run the hostname command.
If the file is empty, unreadable, or has an invalid format, SnapDrive for UNIX does not grant the host access to any of the operations.
Setting up access control from a given host to a given Vserver unit is a manual operation. The access from a given host is controlled by a file residing in the root volume of the affected Vserver unit. This file has the name /vol/<vserver root volume>/sdhost-name.prbac, where host-name is the name of the affected host, as returned by gethostname(3). You should ensure that this file is readable, but not writable, from the host that can access it.
To mount the Vserver root volume on the host system and create
If the file is missing, SnapDrive for UNIX checks the configuration variable all-access-if-rbac-unspecified in the snapdrive.conf file. If the variable is set to on (default value), it allows the hosts complete access to all these operations on that storage system. If the variable is set to off, SnapDrive for UNIX denies the host permission to perform any operations governed by access control on that storage system.
