Configuration command lines
SnapDrive for UNIX commands are used for configuration operations.
The following command-line options are used for configuration operations.
snapdrive config access {show | list} filername -
snapdrive config check luns -
snapdrive config delete appliance_name [appliance_name …] -
snapdrive config list -
snapdrive config set [-dfm] user_name appliance_name [appliance_name …] -
snapdrive config set [-viadmin] user_name viadmin_name -
snapdrive config show [host_file_name] -
snapdrive config check cluster -
snapdrive config prepare luns -count count -
snapdrive config migrate set storage_system_name new_storage_system_nam -
snapdrive config migrate delete new_storage_system_name [new_storage_system_name…] -
snapdrive config migrate list -
snapdrive portset add portset_name filername [filername …] -
snapdrive portset delete filername [filername …]` -
snapdrive portset list -
snapdrive igroup add igroup_name filername [filername …]` -
snapdrive igroup delete filername [filername …]` -
snapdrive igroup list
