Information required for using the snapdrive storage delete command
There is some information that you need to supply before you can use the snapdrive storage delete command. This information helps you in using the command correctly.
| Requirement | Argument | ||
Based on the command you enter, you can delete any of the following types of storage:
The value you enter for the file_spec argument must identify the storage entity you are deleting. |
A LUN ( |
Additional LUNs |
Disk group ( |
name of the disk group or volume group |
File system ( |
Host volume ( |
name of the host volume or logical volume
If you want SnapDrive for UNIX to delete the storage you specify even if you include at the command prompt a host-side entity that has other entities (such as a disk group that has one or more host volumes), include the If you do not include this option, you must specify only empty host-side entities. |
To specify the shared host entity for which you want to delete the storage. |
Optional: Specifies the type of file system and volume manager to be used for SnapDrive for UNIX operations. |
