The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version .
Snapshot operation command lines
01/21/2021
SnapDrive for UNIX commands are used for Snapshot operations.
The following table gives various command-line options for Snapshot operations.
Operation
Command-line options
snapdrive snap create [-lun | -dg | -vg | -hostvol | -lvol | -fs] file_spec [file_spec …] [{-lun | -dg | -vg | -hostvol | -lvol | -fs} file_spec [file_spec …] …] -snapname snap_name [-force [-noprompt]] [-unrelated] [-fstype type] [-vmtype type]
snapdrive snap { show | list } -filervol filervol [filervol… ][-verbose]
snapdrive snap { show | list } [-verbose] {-vg | -dg | -fs | -lvol | -hostvol} file_spec [file_spec…] [-fstype type] [-vmtype type]
snapdrive snap [-verbose] [-snapname] long_snap_name [snap_name …]
snapdrive snap {show |list} [-verbose] [-lun | -vg | -dg | -fs | -lvol | -hostvol] file_spec [file_spec…]
snapdrive snap connect -lun s_lun_named_lun_name [[-lun] s_lun_named_lun_name … ] -snapname long_snap_name [-split] [-clone {lunclone | optimal | unrestricted}] [-prefixfvprefixstr] [-verbose]
In a snapdrive snap connect command, the LUN name should be in the format lun_name or qtree_name/lun_name.
snapdrive snap connect fspec_set [fspec_set… ] -snapname long_snap_name [-autoexpand] [-autorename] [-nopersist] [-mntopts options] [{-reserve | -noreserve}] [-readonly] [-split] [-clone {lunclone | optimal | unrestricted}] [-prefixfv prefixstr] [-verbose]
The fspec_set argument has the following format:
[-vg | -dg | -fs | -lvol | -hostvol] src_file_spec [dest_file_spec ] [{-destdg | -destvg} dgname] [{-destlv | -desthv} lvname]
snapdrive snap rename -old_long_snap_name new_snap_name [-force [-noprompt]]
snapdrive snap restore [-lun | -dg | -vg | -hostvol | -lvol | -fs | -file] file_spec [file_spec …] [{-lun | -dg | -vg | -hostvol | -lvol | -fs | -file} file_spec [file_spec …] …] -snapname snap_name [-force [-noprompt]] [-mntopts options][{-reserve | -noreserve}] [-vbsr [preview|execute]]
snapdrive snap disconnect -lun long_lun_name [lun_name… ] [-fstype type] [-vmtype type][-split]
snapdrive snap disconnect {-dg | -vg | -hostvol | -lvol | -fs} file_spec [file_spec …] [{-dg | -vg | -hostvol | -lvol | -fs} file_spec [file_spec …] …] [-full] [-fstype type] [-vmtype type] [-split]
snapdrive snap delete [-snapname] long_snap_name [snap_name… ][-verbose] [-force [-noprompt]]
