Some configuration commands
There are few commands that help you in configuring SnapDrive for UNIX.
The following table summarizes additional commands that are helpful in configuring SnapDrive for UNIX:
| Command or action | Description | ||
Configuring and verifying your version of SnapDrive for UNIX software |
Check the values in the |
Check the version of SnapDrive for UNIX. |
Start the SnapDrive for UNIX daemon. |
Prepare the host for creating a specific number of LUNs as well as to determine how many LUNs you can create. |
Prepare the guest for creating RDM LUN on Linux guest OS.
Estimate, start, stop, and query the status of split for a volume clone or a LUN clone. |
Edit the variables in the |
Change the path name and options for the log files. SnapDrive for UNIX logs information to three files:
Setting and displaying access control permissions between a host and a storage system. |
Edit the access control permissions file (sd |
Specify the access control permissions a host has on a storage system. You can set the following access levels for a host on a storage system:
Display information about the access control permissions a host has to a storage system. |
Remove the specified user name-password pair from SnapDrive for UNIX. |
