Adding sd- hostname to storage system using CLI
The storage system administrator can create and configure the sd-hostname user using the useradmin command.
Steps
Add storage.
# dfm host add storage_array1 Added host storage_array1.lab.eng.btc.xyz.in
Set the password for the host.
# dfm host password save -u root -p xxxxxxxx storage_array1 Changed login for host storage_array1.lab.eng.btc.xyz.in to root. Changed Password for host storage_array1.lab.eng.xyz.netapp .in
Create a role on the host.
# dfm host role create -h storage_array1 -c "api-*,login-*" sd-unixhost-role Created role sd-unixhost-role on storage_array1
Create a usergroup.
# dfm host usergroup create -h storage_array1 -r sd-unixhost-role sd-unixhost-ug Created usergroup sd-unixhost-ug(44) on storage_array1
Create a local user.
# dfm host user create -h storage_array1 -p xxxxxxxx -g sd-unixhost-ug sd-unixhost Created local user sd-unixhost on storage_array1
