Configuring sd-admin using command-line interface
PDF of this doc site
Administration for Linux
- Role-based access control in SnapDrive for UNIX
Installation and Administration for Solaris
- Creating and using Snapshot copies in SnapDrive for UNIX
Installation and Administration for IBM AIX
Creating your file...
Your file is ready
The storage system administrator can configure sd-admin user using command-line interface.
Steps
Add a user named sd-admin.
# useradd sd-admin
# passwd sd-admin Changing password for sd-admin. New password: Re-enter new password: Password changed
Add an administrator named sd-admin.
# dfm user add sd-admin Added administrator sd-admin.
Create a role named sd-admin-role.
# dfm role create sd-admin-role Created role sd-admin-role.
Add a capability to the role created in step 3.
# dfm role add sd-admin-role DFM.Core.AccessCheck Global Added 1 capability to role sd-admin-role.
The Operations Manager administrator can also grant
DFM.Database.Write
capability on the global group to<sd-admin>
to enable SnapDrive for UNIX to refresh storage system entities in Operations Manager.# dfm role add sd-admin-role DFM.Database.Write Global Added 1 capability to role sd-admin-role.
Add an sd-admin-role role to the sd-admin user.
# dfm user role set sd-admin sd-admin-role Set 1 role for administrator sd-admin.
