Configuring user credentials on SnapDrive for UNIX
The SnapDrive for UNIX administrator receives user credentials from Operations Manager console administrator. These user credentials need to be configured on SnapDrive for UNIX for proper storage operations.
Steps
Configure sd-admin on the storage system.
[root]#snapdrive config set -dfm sd-admin ops_mngr_server Password for sd-admin: Retype password:
Configure sd-hostname on the storage system.
[root]#snapdrive config set sd-unix_host storage_array1 Password for sd-unix_host: Retype password:
Verify step 1 and step 2, using the
snapdrive config listcommand.user name appliance name appliance type ---------------------------------------------------- sd-admin ops_mngr_server DFM sd-unix_host storage_array1 StorageSystem
Configure SnapDrive for UNIX to use Operations Manager console Role-based access control (RBAC) by setting the configuration variable
rbac-method="dfm"`in thesnapdrive.conffile.The user credentials are encrypted and saved in the existing .sdupwfile. The default location of the earlier file is/opt/NetApp/snapdrive/.sdupw.
