Connecting to a Snapshot copy that contains LUNs
You can connect to a Snapshot copy that contains LUNs by using the snapdrive snap connect command.
Steps
Enter the following command syntax to connect to a Snapshot copy that contains LUNs:
snapdrive snap connect -lun s_lun_named_lun_name [[-lun] s_lun_named_lun_name… -snapname long_snap_name [-igroup ig_name [ig_name…]] [-split]`The s_lun_nameandd_lun_nameshould be in the format lun_name or qtree_name/lun_name.
SnapDrive for UNIX clones the LUNs you specify and connects them to a new location.
The following example connects the LUN mylun1, in hornet/vol/vol1/tuesdaysnapshot to mylun1copy:
# ./snapdrive snap connect -lun mylun1 mylun1copy -snapname hornet:/vol/vol1:tuesdaysnapshot connecting hornet:/vol/vol1/mylun1: LUN copy mylun1copy ... created (original: hornet:/vol/vol1/mylun1) mapping new lun(s) ... done discovering new lun(s) ... done
The following example connects two LUNs, mylun1 and mylun2, to mylun1copy and mylun2copy, respectively:
# ./snapdrive snap connect -lun mylun1 mylun1copy -lun mylun2 mylun2copy -snapname hornet:/vol/vol1:tuesdaysnapshot connecting hornet:/vol/vol1/mylun1: LUN copy mylun1copy ... created (original: hornet:/vol/vol1/mylun1) mapping new lun(s) ... done connecting hornet:/vol/vol1/mylun2: LUN copy mylun2copy ... created (original: hornet:/vol/vol1/mylun2) mapping new lun(s) ... done discovering new lun(s) ... done
The following example connects the LUN lun1_0 to snapshot lech:/vol/vol1:rrt:
snapdrive snap connect -fs /mnt/fs /mnt/fs1 -snapname lech:/vol/vol1:rrt
connecting /mnt/fs:
LUN copy lun1_0 ... created
(original: lech:/vol/vol1/lun1)
exporting new lun(s) to Guest OS ... done
Successfully connected to snapshot lech:/vol/vol1:rrt
file system: /mnt/fs1
