Deleting a user login for a storage system
You can delete a user login for one or more storage systems, by executing the snapdrive config delete command.
Ensure that you are logged in as a root user.
Steps
Enter the following command:
snapdrive config delete appliance_name [appliance_name]appliance_name is the name of the storage system for which you want to delete the user login information.
SnapDrive for UNIX removes the user name or password login information for the storage systems you specify.
To enable SnapDrive for UNIX to access the storage system, you must specify a new user login.
