Estimating the storage space to split a volume clone
The clone split estimation helps you to estimate the required storage space (in MB) to split a volume clone. Depending on the clone split estimation provided by SnapDrive for UNIX, you can determine the space availability to split a volume clone.
Enter the following command to estimate the required storage space to split a volume clone.
snapdrive clone split estimate [-lun] long_lun_name [longlun_name…] | [{-dg | -vg | -fs | -hostvol | -lvol} _file_spe [file_spec…]] | [-snapname long_snap_name] {-volclone|-lunclone}] [-v | -verbose] [-dump | -dumpall]This operation displays the following information:
Resource name
Container - Aggregate for a FlexClone
Required Space - space required to split the volume clone
Available space - space available on the container
Storage Status - indicates the space availability for a volume clone split
Owned Space - space occupied by the volume clone
Shared space - space occupied by the volume clone along with the parent
The
Owned SpaceandShared Spaceis displayed when you use-verboseoption. -
The following example estimates the storage space to split a volume clone.
# snapdrive clone split estimate -fs /mnt/my_mnt1 -fs /mnt/my_mnt2
Resource Container Required Available Storage
Space(MB) Space(MB) Status
/mnt/my_mnt1 f3050-220 400 61500 AVAILABLE
-111:aggr0
/mnt/my_mnt2 f3050-220 3292 1129 NOT AVAILABLE
-112:aggr1
For every file specification, SnapDrive for UNIX determines the required space that is available in the storage system to split a volume clone. Here, the /mnt/my_mnt1 file specification has the required space to split, and thus the storage status displays as AVAILABLE. Whereas, the /mnt/my_mnt2 file specification does not have the required space to split, and so the storage status displays as NOT AVAILABLE.
The following is an example of using the -verbose option. Alternatively, you can use -v option.
# snapdrive clone split estimate -fs /mnt/my_mnt1 -verbose
Resource Container Owned Shared Required Available Storage
Space(MB)Space(MB)Space(MB)Space(MB) Status
/mnt/my_mnt1 f3050-220 32365 403 403 55875 AVAILABLE
-111:aggr0
