Generating a CA-signed certificate
The SnapDrive for UNIX daemon service requires that you generate a CA-signed certificate for successful daemon communication. You must provide the CA-signed certificate at the path specified in the snapdrive.conf
file.
You must be logged in as a root user.
You must have set the following parameters in the
snapdrive.conf
file to use HTTPS for communication:-
use-https-to-sdu-daemon=on
contact-https-port-sdu-daemon=4095
sdu-daemon-certificate-path=
/opt/NetApp/snapdrive/snapdrive.pem
Generate a new unencrypted RSA private key in a pem format:
$ openssl genrsa -out privkey.pem 1024
Generating RSA private key, 1024 bit long modulus ....................++++++ ....................................++++++ e is 65537 (0x10001)
Configure
/etc/ssl/openssl.cnf
to create the CA private key and the certificatevi /etc/ssl/openssl.cnf
Create an unsigned certificate using your RSA private key:
$ openssl req -new -x509 -key privkey.pem -out cert.pem
You are about to be asked to enter information that will be incorporated into your certificate request. What you are about to enter is what is called a Distinguished Name or a DN. There are quite a few fields but you can leave some blank For some fields there will be a default value, If you enter '.', the field will be left blank. ----- Country Name (2 letter code) [XX]:NY State or Province Name (full name) []:Nebraska Locality Name (eg, city) [Default City]:Omaha Organization Name (eg, company) [Default Company Ltd]:abc.com Organizational Unit Name (eg, section) []: Common Name (eg, your name or your server's hostname) []:localhost Email Address []:abc@example.org
Use your private key and your certificate to create a CSR:
cat cert.pem privkey.pem | openssl x509 -x509toreq -signkey privkey.pem -out certreq.csr
Getting request Private Key Generating certificate request
Sign the certificate with the CA private key by using the CSR that you have just created:
$ openssl ca -in certreq.csr -out newcert.pem
Using configuration from /etc/pki/tls/openssl.cnf Check that the request matches the signature Signature ok Certificate Details: Serial Number: 4096 (0x1000) Validity Not Before: May 17 06:02:51 2015 GMT Not After : May 16 06:02:51 2016 GMT Subject: countryName = NY stateOrProvinceName = Nebraska organizationName = abc.com commonName = localhost emailAddress = abc@example.org X509v3 extensions: X509v3 Basic Constraints: CA:FALSE X509v3 Key Usage: Digital Signature, Non Repudiation, Key Encipherment Netscape Comment: OpenSSL Generated Certificate X509v3 Subject Key Identifier: FB:B0:F6:A0:9B:F2:C2:BC:50:BF:45:B2:9D:DB:AA:3B:C5:07:5B:7F X509v3 Authority Key Identifier: keyid:FB:B0:F6:A0:9B:F2:C2:BC:50:BF:45:B2:9D:DB:AA:3B:C5:07:5B:7F Certificate is to be certified until May 16 06:02:51 2016 GMT (365 days) Sign the certificate? [y/n]:y 1 out of 1 certificate requests certified, commit? [y/n]y Write out database with 1 new entries Data Base Updated
Install the signed certificate and the private key to be used by an SSL server.
The newcert.pem is the certificate signed by your local CA that you can then use in an ssl server: ( openssl x509 -in newcert.pem; cat privkey.pem ) > server.pem ln -s server.pem `openssl x509 -hash -noout -in server.pem`.0 # dot-zero ( server.pem refers to location of https server certificate)
