Using the SnapDrive configuration wizard
The configuration wizard allows you to configure in NFS, SAN or Mixed environment.
Steps to configure in NFS environment
The following are the steps to configure in NFS environment.
Select the NFS profile.
Enable the Protection Manager Integration.
Select
Yesto enable the access permission checks by using the DataFabric Manager.-
Enter the DataFabric Manager server name or IP address followed by user name and password.
Enter the
http/httpsport to communicate with the DataFabric Manager. The default value is8088. -
Enter the SSL server port to access the DataFabric Manager. The default value is
8488. -
Enable the HTTPs enabled to communicate with the DataFabric Manager.
Select
Noto enable the access permission checks by using the rbac.
Specify the role-based access control methods. The possible values are
nativeanddfm.-
Select
nativeto check the access permission for the host using the control file stored in/vol/vol0/sdprbac/sdhost-name.prbacor/vol/vol0/sdprbac/sdgenericname.prbac. -
Select
dfmto check the access permission using the Operations Manager console.If you select dfmasrbac-methodwithout configuring DataFabric Manager, a warning message specifying that the RBAC method is selected asdfmwithout enabling Protection Manager Integration is displayed.
Specify
httpsorhttpto communicate with the storage system. -
The final step is to save the configuration changes in the
snapdrive.conffile, and restart the daemon.-
If you select
Yes, the SnapDrive daemon is restarted and the configuration changes are reflected. -
If you select
No, the variable values are changed insnapdrive.conffile, but the changes are not reflected.
Steps to configure in SAN environment
The following are the steps to configure in SAN environment.
Select the SAN profile.
Select the required transport protocol.
Select
fcpto set the default-transport. -
Select
iscsito set the default-transport.
Select the SAN Storage Stack (combination of MPIO Solution, volume manager, and file system). The options are
native, andnone. -
Select
Enter the
8488. -
Select
nativeanddfm.-
Select
Select
dfmto check the access permission using the Operations Manager.
If you select dfmasrbac-methodwithout configuring DataFabric Manager, a warning message specifying that the RBAC method is selected asdfmwithout enabling Protection Manager Integration is displayed. -
Enable SMVI integration to create RDM LUNs in the guest OS.
Select
yesto create RDM LUNs in the guest OS. Then enter the IP address, user name and the password of the SMVI server. -
Select
noto skip this option.
SVMI integration is applicable only for FCP Protocol. -
Specify
If you select
If you select
Steps to configure in Mixed SAN and NFS environment
The following are the steps to configure in Mixed SAN and NFS environment.
Select the Mixed profile.
Select
Select
Select the SAN Storage Stack (combination of MPIO Solution, volume manager, file system). The options are
native, andnone. -
Select
Yesto enable the access permission checks by using the DataFabric Manager-
Enter the
8488. -
Select
nativeanddfm.-
Select native to check the access permission for the host using the control file stored in
/vol/vol0/sdprbac/sdhost-name.prbacor/vol/vol0/sdprbac/sdgenericname.prbac -
Select dfm to check the access permission using the Operations Manager console.
Select
Select
Specify
If you select
If you select
SnapDrive modifies the following variables in the snapdrive.conf file.
contact-http-dfm-port -
contact-ssl-dfm-port -
use-https-to-dfm -
default-transport -
use-https-to-filer -
fstype -
multipathing-type -
vmtype -
rbac-method -
rbac-cache
