Starting the volume clone or LUN clone split
You can start a volume clone or LUN clone split operation.
Enter the following command to start a volume clone or LUN clone split.
# snapdrive clone split start [-lun] long_lun_name [long_lun_name…] | [{-dg | -vg | -fs | -hostvol | -lvol} file_spec [file_spec …]] [-force][-noprompt] [-dump | -dumpall]The following options can be used when the storage status displays as NOT AVAILABLE.
You can use the
-forceoption to forcibly start the clone split operation and receive a confirmation message that the operation has started. -
You can use the
-nopromptalong with-forceoption to start the clone split start operation without receiving any confirmation message.
When you start another clone split operation soon after stopping a clone split operation that was in progress, the operation might fail. This issue might occur if the delay between the starting and stopping of the clone split operation was not sufficient to allow the storage system to sync the stop operation. |
The following example displays how to split a volume clone:
# snapdrive clone split start -fs /mnt/my_mnt4_0 /mnt/my_mnt3_0
Resource Container Required Available Storage
Space(MB)Space(MB) Status
/mnt/my_mnt4_0 f3050-220 3295 66033 AVAILABLE
-111:aggr0
/mnt/my_mnt3_0 f3050-220 293 37707 AVAILABLE
-112:aggr1
Job ID: B265Dbv8gh
Clone-Split for "/mnt/my_mnt4_0" is started
Clone-Split for "/mnt/my_mnt3_0" is started
The following example displays how to split a clone using the -force option:
# snapdrive clone split start -fs /mnt/my_mnt5 /mnt/my_mnt6 -force
Space(MB) Space(MB) Status
/mnt/my_mnt5 f3050-220 1198 20033 AVAILABLE
-111:aggr0
/mnt/my_mnt6 f3050-220 3294 2196 NOT AVAILABLE
-112:aggr1
Not enough space available for Clone-Split. Do you want to continue (y/n)?y
Clone-Split for "/mnt/my_mnt5" is started
Clone-Split for "/mnt/my_mnt6" is started
The following example shows how to directly start a clone using the -noprompt option meaning there is no confirmation message:
# snapdrive clone split start -fs /mnt/my_mnt5 /mnt/my_mnt6 -force -noprompt
-111:aggr0
-112:aggr1
