Verifying login information for Virtual Storage Console
You can verify if the virtual interface is configured in SnapDrive for UNIX using the snapdrive config list command.
Enter the following command:
snapdrive config listThis command displays the user name or virtual interface specified in SnapDrive for UNIX. This does not display the passwords for the virtual interface system.
The following example displays the user that is corresponding with a virtual interface named as ruffleskin.
# snapdrive config list user name appliance name appliance type ------------------------------------------------ root rumplestiltskins StorageSystem sdadmin ruffleskin VirtualInterface
