• Product and Solutions
  • Support and Training
  • Cloud Central
  • Community
  • Blog
  • Customer Stories
  • Contact
  • Contact
Menu bars
netapp-mark netapp-logo
  • Home
  • Documentation
  • Snapdrive for Unix
  • Trademark
PDFs
    Site
  • SnapDrive for UNIX 5.3.2 Documentation
  • Sections
  • Install and and Setup for Linux for Clustered Data ONTAP
  • Preparing for deployment
  • Installing SnapDrive for UNIX
  • Verifying Linux host configurations using the configuration checker tool
  • Provisioning storage
  • Creating Snapshot copies
  • Sections
  • Installation and Setup for Linux for Data ONTAP Operating in 7-Mode
  • Sections
  • Administration for Linux
  • Product overview
  • Support for volume migration
  • Management of an LVM and raw entities
  • Understanding the SnapDrive for UNIX daemon
  • Stopping the daemon
  • Support for storage system rename
  • SnapDrive for UNIX configuration
  • Configuring SnapDrive for UNIX
  • Configuration information in SnapDrive for UNIX for guest operating system
  • Configuration information for Vserver
  • Host preparation for adding LUNs
  • Audit, recovery, and trace logging in SnapDrive for UNIX
  • What the trace log file is
  • What AutoSupport is
  • Support for multipath access in SnapDrive for UNIX
  • Multipath setup
  • Thin provisioning in SnapDrive for UNIX
  • Multiple subnet configuration
  • What SnapDrive wizards are
  • Using port set in SnapDrive for UNIX
  • Configuring igroups
  • FlexClone volumes in SnapDrive for UNIX
  • SnapDrive for UNIX operations on FlexClone volumes
  • Security features in SnapDrive for UNIX
  • Access control in SnapDrive for UNIX
  • Login information for storage systems
  • Role-based access control in SnapDrive for UNIX
  • Configuration of role-based access control in SnapDrive for UNIX
  • Configuring sd-admin in Operations Manager console
  • Adding sd-hostname to the storage system
  • RBAC and storage operation examples
  • Storage provisioning in SnapDrive for UNIX
  • Storage operations in SnapDrive for UNIX
  • Storage creation with SnapDrive for UNIX
  • Storage partitioning scheme in Red Hat Enterprise Linux (RHEL) and SUSE Linux Enterprise Server (SLES)
  • Command to use to display available storage
  • Increase in storage size using SnapDrive for UNIX
  • The storage connect command
  • The storage disconnect command
  • The storage delete command
  • Creating and using Snapshot copies in SnapDrive for UNIX
  • What Snapshot operations are in SnapDrive for UNIX
  • Snapshot copy operations
  • Crash-consistent Snapshot copies
  • Snapshot copies information display
  • Snapshot copy rename
  • Restoring a Snapshot copy
  • Restoring Snapshot copies on a destination storage system
  • Volume-based SnapRestore
  • Connecting to a Snapshot copy
  • Connecting Snapshot copies on mirrored storage systems
  • Splitting a volume clone or LUN clone
  • Deleting a Snapshot copy
  • Disconnecting a Snapshot copy
  • Guidelines for disconnecting Snapshot copies
  • Data collection utility
  • Troubleshooting
  • Understanding error messages
  • Error message format
  • Common error messages
  • Standard exit status values
  • Command reference
  • Collecting information needed by SnapDrive for UNIX commands
  • Summary of the SnapDrive for UNIX commands
  • Command summary
  • SnapDrive for UNIX options, keywords, and arguments
  • Sections
  • Installation and Administration for Solaris
  • SnapDrive for UNIX overview
  • Management of VxVM and raw entities
  • Preparing to install SnapDrive for UNIX
  • Hardware and software configuration
  • Preparing your storage system
  • Resetting the snap reserve option
  • Host preparation for installing SnapDrive for UNIX
  • Guest OS preparation for installing SnapDrive for UNIX
  • Installing or upgrading SnapDrive for UNIX
  • Files installed by SnapDrive for UNIX
  • Verifying supported configurations
  • Guidelines for the storage create operation
  • Guidelines for the snapdrive storage disconnect command
  • Guidelines for using the storage delete command
  • Guidelines for Snapshot copy creation
  • Guidelines for connecting Snapshot copies
  • Troubleshooting
  • Command reference
  • Command summary
  • Sections
  • Installation and Administration for IBM AIX
  • Troubleshooting
  • Command reference
  • Command summary
  • Home
  • Release notes
    • Product overview
    • Deployment workflow
      • SnapDrive for UNIX license requirements
      • Supported configurations
      • Linux host requirements
      • Verifying the installation
      • Performing post-installation tasks
      • Importing data files
      • Verifying the supported configurations
      • Provisioning volumes
      • Provisioning RDM LUNs
    • Connecting Linux hosts to storage systems
      • Creating a Snapshot copy
      • Verifying the Snapshot copy
    • Where to go next
    • Product overview
    • Where to go next
    • Product overview
      • Clustered Data ONTAP features available in SnapDrive for UNIX
      • Support for Vserver
      • Support for NetAppDataMotion for vFiler
        • Volume migration in SnapDrive for UNIX
      • vFiler unit support issues
      • Considerations for using SnapDrive for UNIX
        • SnapDrive for UNIX provisioning in an LVM environment
        • SnapDrive for UNIX and raw entities
      • How to manage Snapshot copies of LVM, raw devices, and NFS entities
      • Security considerations
      • Access permissions on a storage system
      • Stack requirements
      • Supported FC, iSCSI, or NFS configurations
      • Limitations
      • Limitations of LUNs managed by SnapDrive
      • Limitations of RDM LUNs managed by SnapDrive
      • SnapDrive limitations for clustered Data ONTAP
      • Limitations for NFS files or directory trees
      • Volume managers on SnapDrive for UNIX
    • New in this release
      • What the Web service and daemon are
      • Checking the status of the daemon
      • Starting the SnapDrive for UNIX daemon
      • Changing the default daemon password
        • Nonforcibly stopping the daemon
        • Forcibly stopping the daemon
      • Restarting the daemon
      • Forcing daemon restart
      • Secure daemon communication using HTTPS
      • Generating self-signed certificates
      • Generating a CA-signed certificate
      • Configuring the new storage system name in a host system
      • Viewing the list of storage systems
      • Migrating from old storage system to new storage system
      • Viewing the migrated new storage system
      • Deleting the storage system mapping information from the host system
        • What the snapdrive.conf file is
        • Configuration options and their default values
        • What the SnapDrive configuration wizard does
        • SnapDrive configuration wizard
        • Some configuration commands
        • Using the SnapDrive configuration wizard
        • Setting values in the snapdrive.conf file
        • Checking the version of SnapDrive for UNIX
        • Configuring Virtual Storage Console for SnapDrive for UNIX
        • Specifying login information for Virtual Storage Console
        • Verifying login information for Virtual Storage Console
        • Deleting a user login for a Virtual Storage Console
        • Login information for the Vserver
        • Specifying login information for the Vserver
        • Verifying login information for Vserver
        • Deleting a user from a Vserver
        • Checking host information
        • Determining how many LUNs can be created
        • Adding host entries for new LUNs
        • Types of logs
        • Enabling and disabling log files
        • Log file rotation settings
        • Contents of an audit log file
        • Changing the defaults for the audit logs
        • Contents of the recovery log
        • Default values for the recovery logs
          • Default values for the trace log files
        • How SnapDrive for UNIX uses AutoSupport
        • Contents of AutoSupport messages
        • Examples of AutoSupport messages
        • Enabling multipathing
        • Multipath setup
          • HBA setup
          • Setting up HBA driver parameter
          • Multipath configuration variables
          • Setting up multipathing
        • Enabling thin provisioning for LUNs
        • Enabling thin provisioning for NFS entities
        • Configuring management and data interfaces for a storage system
        • Viewing all the data interfaces for a management interface
        • Deleting a data interface entry for a management interface
        • LUN names in SAN environment
        • Pure NFS environment
        • Mixed SAN and NFS environments
      • Automatic detection of host entities
        • Operations performed using wizards
        • Managing storage using a wizard
        • Managing Snapshot copies using a wizard
        • Deleting storage using a wizard
        • Adding a port set in SnapDrive
        • Viewing the list of port set
        • Removing a port set from SnapDrive
        • Migrating to new Vserver name
        • Adding an igroup
        • Deleting an igroup
        • Viewing the list of igroups
      • Using Selective LUN Map in SnapDrive for UNIX
        • What FlexClone volumes are
        • Benefits of FlexClone volumes
        • Types of FlexClone volumes
          • Role-based access control for FlexClone volume operations
          • Snap connect procedure
          • Snap disconnect procedure
          • Connecting to a single filespec in a LUN
          • Connecting to multiple filespecs
          • Disconnecting a file specification
          • Splitting the FlexClone volume
          • Space reservation with a FlexClone volume
      • What the Security features are
        • What access control settings are
        • Available access control levels
        • Setting up access control permission
        • Viewing the access control permission
        • Verifying storage system user names associated with SnapDrive for UNIX
        • Deleting a user login for a storage system
      • Setting up HTTP
      • What role-based access control (RBAC) in SnapDrive for UNIX is
      • SnapDrive for UNIX and Operations Manager console interaction
          • Configuring sd-admin using command-line interface
          • Adding sd- hostname to storage system using CLI
        • Configuring user credentials on SnapDrive for UNIX
        • User name formats for performing access checks with Operations Manager console
        • Configuration variables for role-based access control
      • SnapDrive commands and capabilities
      • Preconfigured roles for ease of user role configuration
      • Automatic storage system update on Operations Manager console
      • Multiple Operations Manager console servers
      • Operations Manager console unavailable
        • Operation with a single filespec on a single storage object
        • Operation with a single filespec on multiple storage objects
        • Operation with multiple filespec and storage objects
        • Operation with multiple storage objects
        • Operation with multiple Operations Manager console servers managing storage systems
        • Storage operations across multiple storage system volumes
        • Considerations for storage operations
        • Considerations for provisioning RDM LUNs
        • VMware VMotion support in SnapDrive for UNIX
        • Methods for creating storage
        • Information required for the storage create operation
        • Storage creation for LVM entities
        • Storage creation for a file system that resides on a LUN
          • Supported partition devices
        • Creating LUNs without host entities
        • Creating a file system on a LUN and setting up the LUN automatically
        • Creating a file system on a LUN and specifying the LUN
        • Creating an LVM entity and setting up the LUN automatically
        • Creating an LVM entity and specifying the LUN
        • Methods for displaying storage information
        • Guidelines for the storage resize command
        • Information required for using the snapdrive storage resize command
        • Command syntax to increase the size of the storage
        • Host volumes and file system resize operation
        • Guidelines for the storage connect command
        • Information required for using the snapdrive storage connect command
        • Connecting LUNs with disk groups, host volumes, and file systems
        • Connecting existing LUNs with shared resources
        • Methods for disconnecting storage
        • Tips for using the storage disconnect command
        • Information required for using the snapdrive storage disconnect command
        • Command syntax for disconnecting LUNs from the host
        • Command syntax for disconnecting a file system created on a LUN from the host
        • Command syntax for disconnecting LUNs and storage entities from the host
        • Information required for using the snapdrive storage delete command
        • Considerations when working with Snapshot copies
          • Crash consistency with Data ONTAP 7.2 and later
          • Consistency group Snapshot copies in SnapDrive for UNIX
          • Creating a consistency group Snapshot copy
          • Disabling consistency group Snapshots copies
        • Application-consistent Snapshot copies
        • Snapshot copies that span storage systems or volumes
        • Creating Snapshot copies of unrelated entities
        • Information required for using the snapdrive snap create command
        • Command to use to display Snapshot copy information
        • Guidelines for displaying Snapshot copies
        • Information required for using the snapdrive snap show or list commands
        • Displaying Snapshot copies residing on a storage system
        • Displaying Snapshot copies of a storage system volume
        • Displaying a Snapshot copy
        • Other ways to get Snapshot copy names
        • Command to use to rename a Snapshot copy
        • Renaming a Snapshot copy that spans storage systems or volumes
        • Guidelines for renaming Snapshot copies
        • Changing a Snapshot copy name
        • Command to use to restore Snapshot copies
          • Restoring multiple storage entities
        • Considerations for restoring a Snapshot copy
        • Information required for using the snapdrive snap restore command
        • Restoring a Snapshot copy from a different host
          • What volume-based SnapRestore is
          • Considerations for using volume-based SnapRestore
          • Mandatory checks for volume-based SnapRestore
          • Checks that can be overridden by the user
          • Volume-based SnapRestore command
          • Information about LUNs mapped to local or remote hosts
          • Host filespec information for a particular volume
          • Volume-based SnapRestore for space reservation
        • How the snapdrive snap connect command works
          • Connecting multiple storage entities
        • Snapshot connect and Snapshot restore operations
        • Information required for using the snapdrive snap connect command
        • Connecting to a Snapshot copy that contains LUNs
        • Connecting to a Snapshot copy of storage entities other than LUNs
        • Connecting to Snapshot copies of shared storage entities other than LUNs
        • Estimating the storage space to split a volume clone
        • Estimating the storage space to split a LUN clone
        • Estimating the storage space using a Snapshot copy
        • Starting the volume clone or LUN clone split
        • Viewing the status of a volume clone or LUN clone split
        • Stopping the volume clone or LUN clone split operation
        • Viewing the result of a clone split operation using job ID or file specification
        • Command to use to delete Snapshot copies
        • Reasons to delete Snapshot copies
        • Guidelines for deleting Snapshot copies
        • Information required for using the snapdrive snap delete command
        • Using the Snapshot disconnect operation
          • Guidelines for disconnecting Snapshot copies for NFS entities
        • Information required for using the snapdrive snap disconnect command
        • Disconnecting Snapshot copy with LUNs and no storage entities
        • Disconnecting Snapshot copy with storage entities
        • Disconnecting Snapshot copies with shared storage entities
      • About the data collection utility
      • Tasks performed by snapdrive.dc
      • Executing the data collection utility
      • Examples of using snapdrive.dc
    • Troubleshooting
        • Error message locations
          • Sample error message
        • Operating system limits on open files
        • Deleting LUNs and clones leave stale devices in UNIX
        • Error message values
      • SnapDrive storage create command fails when multiple SAN paths are present but multipathing is disabled
      • If a volume is deleted on the Vserver without unmounting the volume on the host system, the snapdrive storage show command displays the incorrect actual path
      • Snap management operation fails in RHEL/OEL 5.x due to an issue with umount command
      • Snap restore operation fails when you have nfsv3 and nfsv4 versions enabled in the host and storage system
      • Snap disconnect operation fails to delete cloned volume
      • SnapRestore and Snapconnect operations does not work in Linux after multipathing type migration
      • SnapDrive for UNIX reports an error if iSCSI is not running
      • Discrepancy in the error code message
      • Data disappears when you add LUNs to a volume group
      • SnapDrive command fails when the transport protocol connectivity fails
      • Autodetection does not work with MPIO setup for an FS created over a raw LUN
      • Connecting to a Snapshot copy fails
      • Deleting LUNs with exported disk groups on Linux LVM2 fails
      • LUN discovery fails due to iSCSI daemon limitation
      • Commands appear blocked
      • After each reboot snap connect yields "0001-680 Admin error: Host OS requires an update to internal data"
      • SnapDrive errors out if libgcc_s.so.1 is not installed
      • Error loading the /usr/lib/libqlsdm.so in HBA_LoadLibrary
      • Restoring a file system from a Snapshot copy fails
      • Snapshot restore operation fails to restore file system on raw LUN
      • Snap connect operation fails
        • Understanding exit status values of error messages
        • Using exit status values
        • Script example
        • Exit status values
      • Cleaning up the mapped RDM LUNs in the guest operating system and ESX server
      • Volume-based SnapRestore check fails
      • Snapshot create and delete operation fails
      • Unable to create a Snapshot copy
      • Unable to restore a Snapshot copy
      • Unable to restart the daemon when host cannot communicate to the storage system
      • Unable to start the daemon
      • snapdrived start command fails
      • SnapDrive commands sometimes result in mounting or unmounting file systems and modify system files
      • Unable to select a storage stack
      • snapdrived stop or snapdrived start command hangs
      • SnapDrive for UNIX command displays could not check access error
      • Mounting a FlexVol volume fails in NFS environment
      • Receiving error iscsi64 snapdrive: 0001-666 FATAL error
      • SnapDrive for UNIX incorrectly interprets the dollar sign
      • SnapDrive for UNIX displays an error message after SUSE Linux Enterprise Server is upgraded from version 10 to 11
      • SnapDrive for UNIX storage create command fails while discovering some mapped devices
      • SnapDrive for UNIX commands fail with customized LD_LIBRARY_PATH
      • SnapDrive operations fail in multiple subnet configuration
      • SnapDrive for UNIX commands fail when environment variables are set using a command shell
      • SnapDrive for UNIX does not automatically delete stale devices in UNIX
      • SnapDrive fails to add newly mapped LUNs in RHEL 6.6 and later
      • SnapDrive for UNIX operations fails due to improper multipath settings when aliased devices are used.
    • Command reference
        • Collecting information needed by commands
        • General notes about the commands
        • Command summary
          • Configuration command lines
          • Storage provisioning command lines
          • Host-side command lines
          • Snapshot operation command lines
          • Command-line options
          • Rules for keywords
          • Command-line keywords
          • Command-line arguments
      • What SnapDrive for UNIX does
      • Features supported in SnapDrive for UNIX
      • Operations performed on stand-alone UNIX systems
      • Support for guest operating systems
      • Operations supported on host clustered UNIX systems
      • How SnapDrive for UNIX works on host clustered UNIX systems
        • SnapDrive for UNIX provisioning in a VxVM environment
      • How to manage Snapshot copies of VxVM, raw devices, and NFS entities
      • Requirements for storage systems
      • Limitations
      • What configuration checker is
      • Host cluster environment for SnapDrive for UNIX
        • FC or iSCSI configuration checks
        • NFS configuration checks
        • Verification of storage system readiness and licenses
        • Storage system partner IP address or interface name confirmation
        • Guidelines for NFS configurations
        • Storage system volume preparation
        • Volume optimization in an FC or iSCSI environment
          • Resetting the snap reserve option on the storage system
          • Resetting the snap reserve option by using FilerView
        • Installing Solaris Host Utilities
        • Verifying the hosts are ready
        • Verifying that the guest is ready
      • Downloading and decompressing the software package
      • Installing SnapDrive for UNIX on a Solaris host
      • Setting up an SFRAC I/O fencing environment on a storage system
      • Adding a node to a host cluster
      • Removing a node from a host cluster
      • Uninstalling SnapDrive for UNIX from a Solaris host
      • Verifying the Veritas stack configuration
      • Performing post-installation checks
        • Executables installed by SnapDrive for UNIX
        • Configuration files installed by SnapDrive for UNIX
        • Uninstall files installed by SnapDrive for UNIX
        • Diagnostic files installed by SnapDrive for UNIX
        • Man pages installed by SnapDrive for UNIX
      • Upgrade SnapDrive for UNIX to current version
      • Identifying the installed components
      • Adding an igroup
        • Types of logs
        • Reason to refresh the DMP paths
      • Setting up HTTP
          • Guidelines for storage create operation in a host cluster environment
        • Storage creation for VxVM entities
        • Creating a VxVM entity and setting up the LUN automatically
        • Creating a VxVM entity and specifying the LUN
        • Guidelines for storage connection in a host cluster environment
          • Guidelines for using the disconnect command in a host cluster environment
        • Disable a node or a cluster from using shared resources
          • Guidelines for storage deletion in a host cluster environment
          • Guidelines for Snapshot copy creation in a host cluster environment
          • Restoring a single storage entity on a storage system or storage system HA pair
          • Guidelines for restoring a Snapshot copy in a host cluster environment
          • Connecting a single storage entity on a storage system or storage system HA pair
          • Guidelines for connecting Snapshot copies in a host cluster environment
          • Guidelines for disconnecting Snapshot copies in a host cluster environment
    • Troubleshooting
      • Volume-based snap restore operation fails in slave node
      • Snap restore command fails to mount the file system
      • Storage connect operation fails to connect to a LUN created on a storage system using the LUN create command
      • SnapDrive for UNIX does not show the supported file system types for storage create operation
      • Creating a file system directly on a LUN fails
      • After rebooting the host, OS and cluster services fail to start
        • Script example
      • Some commands are delayed when the storage cluster is in failover mode
      • Storage area network file specification created with Solaris Volume Manager using iSCSI does not mount automatically
      • Storage disconnect of disk group fails
    • Command reference
        • Command summary
      • Limitations
      • Multipathing in SnapDrive for UNIX
        • Installing AIX Host Utilities
      • Decompressing the downloaded software
      • Installing SnapDrive for UNIX on an AIX host
      • Uninstalling SnapDrive for UNIX from an AIX host
      • Adding an igroup
        • Types of logs
      • Setting up HTTP
    • Troubleshooting
      • Clustering message appears during SnapRestore
        • Script example
      • (AIX) MPIO cfmode support limited
      • Ghost device handles in AIX cause longer return time on iSCSI commands
      • Cannot install SnapDrive for UNIX patches on AIX by default
    • Command reference
        • Command summary
  • Legal notices
Trademark
01/21/2021 Contributors netapp-ivanad akseldavis Download PDF of this page
NETAPP, the NETAPP logo, and the marks listed on the NetApp Trademarks page are trademarks of NetApp, Inc. Other company and product names may be trademarks of their respective owners.
http://www.netapp.com/us/legal/netapptmlist.aspx
CONTRIBUTE
Edit on GitHub Request doc changes Contributor's Guide
ON THIS PAGE
    • © 2021 NetApp, Inc.
    • blog blog@
    • community community@
    • twitter twitter@
    • facebook facebook@
    • linkedin linkedin@
    • youtube youtube@
    • slideshare slideshare@
    Have feedback for our website?Let us know Announcements
