Performing post-installation tasks
After the installation is complete, you must configure additional features and functions. You must install the server certificate and configure SnapDrive for UNIX to use a secure connection with the storage system and daemon service.
Install the server certificate that is used by SnapDrive for UNIX in the
sdu-daemoncertificate-path=/opt/NetApp/snapdrive/snapdrive.pemlocation if you are using a secure connection with the storage system and daemon service.The certificate path is defined in the
sdu-daemoncertificate-pathconfiguration variable in the s`napdrive.conf` file. -
Set
use-https-to-sdu-daemon=onin thesnapdrive.conffile to use HTTPS for a secure connection with the storage system and daemon service.SnapDrive 5.0 for UNIX and later versions support HTTPS for daemon communication. By default, this optional parameter is disabled. -
Restart the SnapDrive daemon service:
snapdrived startYou must restart the SnapDrive daemon every time you manually change the configuration file.
