SnapDrive for UNIX license requirements
Before you install SnapDrive for UNIX, you must ensure that you have the appropriate licenses for the required software and protocols.
SnapDrive for UNIX license requirements are as follows:
| License | Description | Where installed |
SnapRestore |
A required license that enables SnapDrive for UNIX to restore Snapshot copies. |
On NetApp storage systems |
FlexClone |
An optional license for cloning Snapshot copies. |
Protocols |
Required for LUNs, the iSCSI or FC license. |
