SnapDrive SDDiscoveryFileSystemListInfo response is null while backing up
Issue
You receive the error
SnapDrive SDDiscoveryFileSystemListInfo response is null while backing up. -
Cause
This message occurs when the SnapInfo location to which you are backing up is not available.
Corrective action
Verify that the SnapInfo location exists and is available. If it has changed, re-run the configuration manager to specify the new location. Attempt the backup again.
Related information
