Vss Requestor - Backup Components failed. An expected disk did not arrive in the system
Cause
This message occurs when you back up a dataset using SnapManager for Hyper-V and the following error appears in the Windows Application event log on the Hyper-V host.
A Shadow Copy LUN was not detected in the system and did not arrive. LUN ID guid Version 0x0000000000000001 Device Type 0x0000000000000000 Device TypeModifier 0x0000000000000000 Command Queueing 0x0000000000000001 Bus Type 0x0000000000000006 Vendor Id vendor Product Id LUN Product Revision number Serial Number serial_number Storage Identifiers Version 0 Identifier Count 0 Operation: Exposing Disks Locating shadow-copy LUNs PostSnapshot Event Executing Asynchronous Operation Context: Execution Context: Provider Provider Name: Data ONTAP VSS Hardware Provider Provider Version: 6. 1. 0. 4289 Provider ID: {ddd3d232-a96f-4ac5-8f7b-250fd91fd102} Current State: DoSnapshotSet -
Corrective action
Retry the dataset backup.
