SnapManager for Hyper-V
Hyper-V parent host requirements
Hyper-V parent hosts are physical servers on which the Hyper-V role is enabled. Host servers that contain virtual machines are added to SnapManager for Hyper-V for protection and recovery. To install and run all of the SnapManager for Hyper-V software components, you must ensure that the Hyper-V parent hosts meet minimum operating system and Hyper-V requirements.
  • Supported operating systems
    SnapManager for Hyper-V runs on the following operating systems:
    • Windows Server 2008 R2 SP1
    • Windows Server 2012 R2
    • Windows Server 2016
    • Windows Server 2019
  • Supported management console operating systems
    Management consoles must be running the following operating systems:
  • Hyper-V requirements
    For more information, see the Hyper-V getting started information in the Microsoft TechNet library.
  • Internationalization support
    SnapManager for Hyper-V has been tested on German-language and Japanese-language operating systems.
Related information
