Restore failure after storage system volume renaming
Message
Some of the storage system snapshots required to restore the VM are missing or inconsistent. -
If storage system volumes are renamed, you cannot restore a virtual machine (VM) from its backup that was created prior to renaming volumes.
Corrective Action
If storage system volumes are renamed and you need to restore a VM from a backup created prior to renaming volumes, then complete the following:
While restoring a VM from MMC, make sure that "Enable Snapshot Verification" option is unchecked in the Restore Options page of the Restore wizard.
While restoring a VM by using PowerShell, make sure that -
DisableVerifySnapshotparameter is specified.
