Restore from a backup after failback
Issue
If you perform a failover and failback, you may not be able to restore VMs on your primary site from a backup created on the same primary site, before the failover.
Cause
Snapshot copy verification uses volume GUIDs. GUIDs changes after disaster recovery.
Corrective Action
You can disable the Verify Snapshots option through the PowerShell or the Restore wizard:
Uncheck the "Enable Snapshot Verification" option in the Restore Options page of the Restore wizard.
Using PowerShell, make sure that -
DisableVerifySnapshotparameter is specified.
Related information
