SnapManager for Hyper-V
Some types of backup failures do not result in partial backup failure
  • Issue
    If one virtual machine in a dataset has an error, SnapManager for Hyper-V does not successfully complete the dataset backup, and in some scenarios, does not generate a partial failure. In these situations, the entire dataset backup fails.
  • Example
    In a scenario where one storage system volume exceeds the 255 Snapshot copy limit, SnapManager for Hyper-V generates a partial failure even though the problem is associated with a subset of virtual machines in the dataset.
  • Corrective action
    To successfully complete the backup operation, you need to fix the virtual machine that has the issue. If that is not possible, you can temporarily move the virtual machine out of the dataset, or create a dataset that only contains virtual machines known not to have a problem.
