Add a Hyper-V parent host or host cluster
You can add a Hyper-V parent host or host cluster to back up and restore your virtual machines.
Steps
From the navigation pane, click Protection.
From the Actions pane, click Add host.
Run the Add host wizard.
After you finish
When you add a host to a cluster, the information about the new host is not automatically displayed in the GUI. Manually add the host information to the xml file in the installation directory.
SnapManager for Hyper-V must be installed on each cluster node. If you do not have SnapManager for Hyper-V installed, you are prompted to run the Remote Host Install wizard.
