Add policies
You can add retention, scheduling, and replication policies, as well as scripts, to your datasets so that you can protect your data.
What you'll need
You must have the following information available:
Policy names and descriptions
Retention information
Scheduling information
Backup options information
Backup script information
Steps
From the navigation pane, click .
Select the dataset to which you want to add policies.
From the Actions pane, click Add policy.
The Create Policy wizard appears.
Complete the steps in the wizard to create protection policies for your dataset.
