Delete policies
You can delete a policy from a dataset when it is no longer needed.
Steps
From the navigation pane, click .
Select the dataset that contains the policy that you want to delete.
From the Policies pane, select the specific policy that you want to delete.
From the Actions pane, click Remove and click OK to delete the policy.
Deleting the policy also deletes the scheduled jobs from all hosts that are members of the dataset.
