Install SnapManager for Hyper-V
You can install SnapManager for Hyper-V so that you are able to back up and restore your data. You should install SnapDrive for Windows before installing SnapManager for Hyper-V.
What you'll need
Your existing data must be backed up, and you must have the following information ready:
License key
Login credentials
Port number (default: 808; must match the SnapDrive for Windows installation port number)
Steps
Double-click the SnapManager for Hyper-V executable file to launch the SnapManager for Hyper-V installer.
Select the installation location and click Next.
Complete the steps in the SnapManager for Hyper-V Install Shield wizard.
Click Install on the Ready to Install page.
Review the summary of your selections and click Finish.
Related information
