Manage storage connection settings
After you have added a host, you should enter all of the storage connections (SnapDrive for Windows and SnapManager for Hyper-V) for using Manage Storage Connection Settings in .
What you'll need
You must have at least one host added to SnapManager for Hyper-V before you can manage your storage connection settings.
Steps
From , select the Manage Storage Connection Settings.
Add the storage connections.
All storage connections can be viewed in SnapDrive for Windows TPS.
