Manually backing up a dataset
You can create an on-demand backup of a dataset.
What you'll need
You must have the following information available:
Backup name and description
Policy name, if necessary
Policy override information (if you plan to change any of the previously specified policy options)
Backup type
Backup options information
Steps
From the navigation pane, click .
Select the dataset for which you want to create a manual backup and click Backup.
The Backup wizard appears.
Complete the steps in the wizard to create your on-demand backup.
Closing the wizard does not cancel the on-demand backup.
Results
You can view the status of the on-demand backup in the Jobs Management window.
