SnapManager for Hyper-V
Migrate a Hyper-V virtual machine for SnapManager for Hyper-V operations
SnapManager for Hyper-V does not contain a migration wizard to help you migrate virtual machines (VMs) from non-ONTAP storage to ONTAP storage so that you can use them with SnapManager for Hyper-V. Instead, you must manually export and import the VM by using Server Manager.
