Modify a dataset
After you have created a dataset, you can modify the dataset description and the resources associated with the dataset.
About this task
The Validate Dataset check box is selected by default. SnapManager for Hyper-V checks for any configuration errors in all VMs during the creation or modification of a dataset. You must ensure that the check box is not selected if you do not want to enable validation of the dataset.
Steps
From the navigation pane, click .
Select the dataset that you want to modify.
From the Actions pane, click Modify dataset.
Complete the steps in the wizard.
