Modify policies
You can modify the policies that protect your datasets by using the Modify Policy wizard.
Steps
From the navigation pane, click .
Select the dataset that contains the policies that you want to modify.
Select the policy that you want to modify.
From the Actions pane, click Modify policy.
The Modify Policy wizard appears.
Complete the steps in the wizard to modify the protection policy for your dataset.
