SnapManager for Hyper-V
Monitor backup jobs
You can view the scheduled backup jobs for a particular dataset by using the Jobs Management windowScheduled tab. You can also view the backup and restore jobs that are currently running by using the Jobs Management windowRunning tab.
Steps
  1. From the navigation pane, click Jobs.
  2. Click either the Scheduled tab or the Running tab.
  3. Select the scheduled or running backup job, or the restore job, that you want to monitor.
    Information about the job appears in the Details pane.
  4. Use the Running Job report in Reports view, if you want to view a live report of a running job.
    Note You can also monitor backup jobs with Microsoft's SCOM console. See the Microsoft web site for more information.
