Remotely install or uninstall SnapManager for Hyper-V on nodes or hosts
The Remote Host Install wizard enables you to remotely install or uninstall SnapManager for Hyper-V on standalone and cluster hosts or nodes. You can remotely install SnapManager for Hyper-V if you want to install the software on all nodes of a cluster at one time instead of installing it on each individual node.
What you'll need
You must already have SnapManager for Hyper-V installed on a host node to use the Remote Host Install wizard.
Steps
From the navigation pane, click Protection.
From the Actions pane, click Remote Host Install.
Run the Remote Host Install wizard.
Result
When you run the Remote Host Install wizard, the host node pushes SnapManager for Hyper-V installation or uninstallation to other nodes or hosts in the cluster.
