Restore the original configuration for clustered hosts
After the VMs are backed up on the primary storage system, you can return to the original configuration using a SnapMirror relationship which is established from the primary storage system to the secondary storage system.
Steps
Offline the virtual machine resource and virtual machine configuration resource for all the VMs.
Delete these resources from the cluster.
Delete all the VMs from Hyper-V Manager.
Disconnect all the disks by using SnapDrive.
Resynchronize the SnapMirror relationship from the primary storage system to the secondary storage system.
