SnapManager for Hyper-V
Restore the original configuration for standalone hosts
After the VMs are backed up on the primary storage system, you can return to the original configuration using a SnapMirror relationship that is established from the primary storage system to the secondary storage system.
Steps
  1. Shut down the VMs running on the secondary storage system.
  2. Delete the VMs running on the secondary storage system.
  3. Disconnect the SnapInfo disk and the disks containing VMs using SnapDrive.
  4. Resynchronize the SnapMirror relationship from the primary storage system to the secondary storage system.
