View a Hyper-V parent host or host cluster
You can view configuration information about a specific Hyper-V parent host or host cluster so that you can monitor its status.
Steps
From the navigation pane, click .
Select the host or host cluster that you want to view.
The Details pane displays the host or host cluster name, domain, cluster members (if applicable), and configuration messages. If you select a host that is not configured, the Details pane displays information about what is not configured.
