View a dataset report
You can view a report about a dataset or virtual machine resource managed in SnapManager for Hyper-V.
Steps
From the navigation pane, click .
Select the dataset or virtual machine that contains the report you want to view.
From the Reports pane, click either the Backup tab or Recovery tab.
Select the report that you want to view and click View report.
If you want to view a… Then… dataset report
You can view a backup report.
virtual machine report
You can view either a backup or recovery report.
The report appears in a separate window.
