View installed VSS providers
You can view the VSS providers installed on your host.
Steps
Select and enter the following command to open a Windows command prompt:
cmd -
At the prompt, enter the following command:
vssadmin list providersThe output should be similar to the following:
Provider name: ‘Data ONTAP VSS Hardware Provider’ Provider type: Hardware Provider ID: {ddd3d232-a96f-4ac5-8f7b-250fd91fd102} Version: 7.0.0.xxxx
